I am looking for the best possible light with an infinitely variable control ring that takes an 18650.
Total stock output is not important because I am going to have it modded with an XM-L2 and a current boost on max. I am leaning toward a control ring light with detents so I can tell what mode it will turn on in. I also prefer to have one with an on/off switch so there is no drain from it always being in standby mode.
The Sunwayman V20C seemed to fit the bill, but I don't really like the feel of those grip rings, and the V20C just doesn't look right without it. The new V25C doesn't have any detents so it would be hard to tell what brightness the light will turn on it.
After a lot of searching, I am leaning towards the Jetbeam RRT-21. Outside of the cheap clip which I'll remove, it looks like a great control ring 18650 light with all the features I'm looking for.
Any others I should consider?? Thanks in advance!
