I have both, and for most uses I prefer the QT2A-X. It has a brighter beam (for the first 3 minutes), which mostly compensates for the extra throw you get from the QT2A. The QT2A-X also has a broader spot, which is great for close and moderate distances. Note that the QT2A-X steps-down from max brightness after 3 minutes to prevent over-heating, so for constant use after 3 minutes the QT2A is slightly brighter (since it doesn't step down).
As you likely already know, the QT2A has a tighter spot, which gives you extra throw. Handy for outdoor use, especially at greater distances. But for indoor use, the floodier QT2A-X is much better. And as mentioned, since the QT2A-X is brighter on all modes (except after its step-down from max), the lack of throw is partially compensated by its greater brightness.
The QT2A does have an advantage when it comes to efficiency on low modes, especially moonlight. Its moonlight is a bit dimmer than the QT2A-X (about two-thirds as bright), but it lasts twice as long... a whole month of constant usage! But that's probably far longer than you need, so that advantage is mostly academic.
Overall, they're both great lights, and I don't think you can go wrong with either. But, I give the edge to the QT2A-X (or the QP2A-X which I like even more).
