DaFABRICATA
This is a build from several months back.
McGizmo S27-PD host.
1 peice Aluminum heatsink
3 x McR12 reflectors
3 x Nichia 219 emitters
3 mode 3A driver
Custom power contact
The solid aluminum heatsink was machined to fit the reflectors, emitters, and driver in a single drop-in assembly.
Only the power/ground need to be soldered and the set-screw secured on the bottom of the head.
The power/ground contact ring needs to be finished nicer but has just been getting use instead.
The front end needs to be repolished due to handling and storage between other builds.
Those McR12 reflectors do a great job of providing a good amount of throw and smooth spill.
Not much else to say, so here's some pictures.
3 mode 3A driver
