RaccoonExplorer
This is a short review of the SMALL SUN ZY-T08, my first review actually , mostly concentrating on beam shots. I was curious to see how far this lamps could throw and i tested it last fall. Well, to say the least it went beyond my expectations ! This lamps have the farthest throw of any 'pocket' lamps that i have ever seen in its price range, while also beating lamps that cost several times more or that use several more XML-T6 LED emitters, and does this in a much more efficient, more compact package. Still, it have quite a large head due to the large reflector, not practical to carry in a jeans pocket but quite easy to carry in a coat pocket, or else in a shoulder bag.
This is a beam shot of the ZY-T08 from Small Sun in a soccer field. The ZY-T08 uses a single XML-T6 LED emitter. Shot taken with the lamp at its highest power setting. Distance to the trees is roughly 100 meter.
Now compare the shot above to this beamshot from an UltraFire lamp which uses 3 XML-T6 emitters (versus the single emitter of the Small Sun ZY-T08). Shot taken with the lamp at its highest power setting.
As you can see there is a lot of throw but the central part of the beam for the Small Sun ZY-T08 is so concentrated it completely obliterates the more powerful (estimated at 1650 Lumen according to my calculations) Ultrafire and its 3 XML-T6 emitters (installed in smaller individual reflectors).
The huge deep dish reflector of the ZY-T08 with its high reflection coating is clearly making the difference and focuses its beam much more tightly and further away, as you will see on the pictures i will post below. In terms of pure throw, the Small Sun ZY-T08 also beats the more powerful 3 LED Ultrafire, in my tests (which i will publish in more detail about that specific lamp later on) i got a range of only about 265 meters for the Ultrafire with 3 XML-T6 emitters.
The Small Sun is rated at 640 Lumen, versus 1650 Lumen for the 3 XML-T6 UltraFire (according to my estimates, not according to what's written on the body of the lamp which gave a '4000 Lumen' which is far more than 3 hard driven XML-T6 could give in reality)(more on this later).
I will add the more detailed info regarding camera and lens settings soon.
