Hey guys, so I've had my SWM V11R for about 2 weeks now. It's been working stellar with Battery Station CR123s. The only mod I've done to it was to add some Superlube grease inside the control ring and add a shim to the ring to remove play and to not let grease leak out anymore. Anyways, a problem just cropped up today. This occurred with a 2.9V BS CR123 and a new BS CR123.
It seems that when the light is given a sharp jolt, like flicking the wrist with light in hand, the light turns off, then turns back on. Now what's interesting is, that when it is at max lumens, it works perfectly and never resets. However, as the control ring is adjusted lower, it becomes easier for the light to reset, meaning it takes less force to reset the light as the lumens decrease. When the light resets, it usually takes about 1-2 second for the light to reach its normal brightness.
The only time I dropped the light was today, about 1.5 feet onto hardwood flooring onto its side. Could this be the reason why this is happening? If so, that's disappointing about the light's quality.
Anyone have any suggestions on how to fix this?
Thanks for your time.
