Mark_Larson
So i was playing with this pewter Mini-mag with a BB400/Q2 and fresh alkalines.
The optic was a NX-01, and i also tried it with a McFlood. It was nice.
Then i got the idea - why not try to mod the stock reflector to fit?
So i looked at both reflectors and noted the McFlood's hole diameter with my highly accurate optical equipment (my eyes).
Then i proceeded to go to work on the blue plastic with my girlfriend's smallest kitchen knife (eXacto? pfft!)
After much whittling and blowing of shavings i had come up with something that just about worked. I tried it, then realised the flanges were interfering. After a few minutes of playing around with the light, i realised i should file the flanges down.
I of course didn't have a file, so i cut them off with the same knife, flush with the reflector body.
Now its working, but it doesn't look too good. The LED isn't properly centered (the whole reflector doesn't look yellow when you look at it dead-on) but i think i can make it work.
Its the brightest at turn-on point - when the head is turned just enough to turn it on. The light is flood-ish, and of course has some artifacts from the smooth reflector. If you turn it further, a hole appears in the center - while not as dark as the hole in the stock light, it is nonetheless there.
Any tips? /ubbthreads/images/graemlins/grin.gif
Pics will come tomorrow or the day after, when i have access to a digital camera.
