Hi folks!
I just had a Eagletac D25a clicky (XM-L2 U2) delivered from goingear.com and I got a couple of 3.7 volt Eagletac 14500's (750mah) with it.
I charged up the 14500's and they absolutely outshine my Eneloops by a longshot.
One thing I noticed is that with the Eneloope, I have low, medium and high modes with the twisty loosened up a bit, and then both turbo and strobe when the cap is tightened. The turbo (with cap tightened) is clearly a higher output than with the cap looser, in just high mode.
However, with the 14500 battery, the turbo mode is identical to the high.
I bought the XM-L2 U2 model specifically thinking that I would get an extra turbo boost in direct drive with the 14500's, up to a reported (manufacturer) 750 lumens. So, are both my "high" and "turbo" mode putting out direct drive turbo @ 750 lumens or so, or is my light not functioning correctly, because with the 14500, both "high" and "turbo" are the same thing.
Thanks for any input! I like the light - it's super bright and compact for a AA/14500, but I want to make sure I got what (I thought) I paid for.
Burns
Burns
