I thought it was some kind of epoxy with aluminum in it, which means it would conduct electricity, but see in some mod descriptions that it might not be that way.
I want to put an R2H Luxeon into a #222 screw-base incandescent bulb shell and direct drive it from 1x123. I'm trying to figure out what to use as a heat sink. The host light would be a Tekna Splash-Lite which is a lightweight plastic light, so it doesn't have much heat sinking capability of its own, though the reflector and retaining ring do hold a little heat.
Can I fill the bulb base with Arctic Alumina and not short the LED leads with it? Will that be enough heat sinking for the underdriven R2H? I've been running the light with a K222 600 mA krypton bulb which does get pretty warm in there.
