m4a1usr
Anyone ever do a volts out mod to a KL4/LX2 Surefire LED driver? I have been wanting to use the stock driver out of those heads/ lights to drive an XML EZW LED but mine only put out 5.5 volts. That's not enough to drive the XML EZW or even an MCE decently. I did find one in a KL4 head of mine that did put out 5.8 volts and there was a huge difference in output but the XML EZW runs much better at 6 volts or even 6.3 volts.
I tried an RCR123 with a CR123 in one of the 5.5v SF drivers and did get 5.9 volts out but we all know not to mix chemistries or battery types. Two RCR123 and the 5.5v SF driver put out 6.5 volts but it gets pretty warm and I'm not comfortable at this point committing to that. Figured maybe one of you fellow modders might have already tackled this issue? TIA
