crucialcolin
- Joined
- May 17, 2014
- Messages
- 52
Just wanted to post up some shots and thoughts about my led flashlights after winning a Nitecore TM11vn here in the giveway thread. Thanks again thedoc007!
Anywho before recently the only LED based flaslights I had were maglites with LED modules. MY 4D had an official mag lite drop in bulb replacement. Then my AA mag had a terralux tle-5ex. For whatever reason my 4D liked to eat D cell alkaline for lunch if I left it sitting around any with the batteries inserted. I'm talking about a month or two time frame. Then my AA which seemed to get great battery life but the dome on the LED module recently melted off. Thus I figured it probably wont last much longer. Thus my search for better lights began. Around the same time I got the TM11vm I also bought a Thrunite TN2014.
here are the comparison shots I took tonight in a local park with my Panasonic FZ200 using manual settings and with each light at its max output level. Not sure of the distance of these since I am by no means an expert at beam shots.
First up is the Mini maglite AA with Teralux:
Second is the Big 4D LED Maglite:
Third is the Thrunite TN2014
Lastly the awesomeness that is the TM11vn
Then here are two additional shots between the TN2014 and TM11vn.
As you can see both the Thrunite TN2014 and Nitecore TM11vn put the maglites to shame.
