I'm building a fish tank LED lighting array from 10x 5watt Creee XTE LED's Natural white bin purchased from AliExpress for about $1each.
Power supply is 65watt laptop PSU connected to a Voltage and current adj. buck driver with PWM input (for planning micro-controller light level control).
I have two arrays of 5x LED's each mounted with thermal paste and screws to old Pentium III heat sinks (currently with no fans, I was hoping to have passive cooling)
They seem to perform exactly to the CREE spec sheet, so they are likely not counterfeit?
Anyway, I was putting the rig through a bench test too see how warm it ran at close to ~1.5amp (Max rating)
The heat sinks get hot to the touch, but not hot enough to be uncomfortable, which unscientifically is in the 70-80degC range I wanted to check the temp of the LEDs and stuck my finger on one (as I had done before) and the Silicone dome / phosphor disintegrated ! :sigh:
I will be ordering some spare LEDs, but I actually needed more blue in the array as it was a bit too green for my taste.
1) I was concerned that it is now emitting UV light, as it has that hue to it, but after some reading it seems that it is emitting Royal blue?
2) Is their something I can apply to the die to protect it?
3) are 90deg lenses worth the cost in this application? (was planning acrylic cover)
I might write up something on the PWM Drivers once I have it working with my micro-controller (Ti stellaris launchpad) as there is not much information on them around.
