yes, ventilation holes will be needed,
because, like i said before, i´m running out of time, and i had to make some changes to the original idea that was to extend the body with metal mesh or something.
i had to use a different heatsink that fits inside the original body.
there you can see my custom battery pack, i made frames with laser cutted acrylic,
and the plug for the charging circuit
i made some modification to the booster heatsink
Here are all together inside
i found out that reducing the output voltage of the booster to 27v, the led only consume 670mAh, and the fan will not be needed, i turned it on for 10 minutes continuous, the battery only drops near 2 volts, the led does not emit too much heat, the light is less but still rocks
any way, i´ll drill the vent holes and set the voltage like it supposed to be, then :naughty: I´ll carry a bit of the sun in my backpack
