Overclocker
Klarus' dual-button tailcap design has been around for quite a while and has been very well received, providing users with direct access to strobe as well as the ability to change modes without changing your grip on the flashlight. The 3rd-generation of this design incorporated a metal "lever" over the strobe button. It was only a matter of time before someone would copy it
(Nitecore P20 left. Klarus XT11 right)
Let's leave it to these two companies to duke it out in the courts but the similarity is obvious to say the least... Nitecore's "lever" seems to be die-cast metal, while Klarus' is stamped metal. The Klarus requires greater force to activate and has no tactile feedback. The Nitecore needs a very light push and has some tactile feedback, but with no audible click. I hate to say it but the copycat seems to have the better strobe button...
P20, smooth and very shallow which means a WIDE spillbeam i.e. less tunnel vision. XT11 has a deeper, heavily-textured reflector so has a smoother hotspot-to-spill transition
P20 clip "lands" at the wrong spot. Very thin and flexy. XT11's is better
USER-INTERFACE
XT11: Main button always starts at HIGH. Once on, short-press with strobe button changes levels, descending (HIGH, MID, LOW). From OFF, the strobe button activates strobe (short press momentary, long press activates strobe continuously)
P20 is a bit more complicated. Has 3 mode groups. But strobe button always strobes from OFF (ALWAYS momentary only) in any mode group
Group1 P20 "Tactical Mode". Main button always starts at HIGH. Once on, strobe button toggles between strobe and high (long and short presses do the same thing)
Group2 P20 "Law Enforcement Mode". Main button always starts at HIGH. Once on, short presses on strobe button toggles between high and med (long press activates strobe)
Group3 P20 "General Mode". Main button starts at memorized mode, either low, med, high, or strobe (YES strobe can be memorized for the main button). Once on, short presses on strobe button changes levels (L, M, H) in ASCENDING order (long press activates strobe)
To change mode group, loosen head slightly, then press and hold the strobe button, then tighten head. The P20 flashes 1x, 2x, or 3x (tactical, LE, general mode, respectively). Repeat to get to the desired mode group.
CONCLUSION
Unfortunately for Klarus their latest version of the strobe button does feel very "mushy". I actually prefer the bare rubber switch without the metal lever over it. So I have to say the Nitecore implementation is better, though it does activate a bit too easily. Not a deal-breaker through.
I leave it to you to decide which UI works better for you but I have to point out that there's no mode group in the Nitecore that completely emulates the Klarus' behaviour. However I have to say that the Nitecore "General Mode" does allow it to be suitable as a general-purpose flashlight, something the Klarus couldn't do very well. Unfortunately the Nitecore's LOW setting doesn't go as low as the Klarus'...
The Klarus does have an advantage with the stainless steel bezel. Sharper and more agressive crenellations compared to the Nitecore.
