Hey guys
I dont think I've ever posted before, but I lurk frequently. I recently purchased a zebralight sc600 ii l2. This also required I purchase my first 18650 batteries, charger, and a multimeter. I wound up with 4 Panasonic 3400 mah batteries off amazon and a nitecore charger. All of my batteries are coming off the charger at 4.20 to 4.21 volts, and run fine at first, which leads to my problem.
None of the batteries seem able to run the flashlight on high after they discharge to 4.08 and below. The light will flash on h1 briefly and then won't go above m1. It will still strobe on high, but that's it.
This doesn't seem to give me very much usable runtime. I'm wondering if this is normal and I'm expecting too much, or possibly the batteries I selected cant supply the necessary current once the voltage drops? The lights battery indicator is giving me 3 flashes still.
If anyone can give me some advice here I would appreciate it, I'm slightly out of my depth with this jump to rechargables . Also if I should have put this in a specific sub forum I apologize, I didn't see anywhere specific this would fit.
Thanks
Kevin
Thanks
Kevin
