So I was thinking about how awesome it would be if my V11R had an 18650 instead of a CR123A. It would make it a bit longer, but I think it's a bit too short to be really comfortable anyway, without being a real "tiny" EDC, as it's rather fat. So I had a look at the Sunwayman site and it appears that the closest thing that actually exists is the V20C, which is a completely different design. I don't like it for a variety of reasons including the Nitecore-style tail, but most importantly, it's a lot bigger so wouldn't be nearly as pocketable.
I was wondering if there is a technical reason for this not to exist, or indeed if anyone has made something like it out of off the shelf or custom parts. To be clear, I'm talking about exactly the same format as the V11R, just a bit longer. The battery tube would need widened internally and might not fit every 18650, but I normally use Eagletacs (protected 3400mAh), which from the looking at it, should fit with little or no external redesign: at most, the grip pattern on the tube might need to change a bit.
Would it work though? Would it be too thin? Would that badly affect the heat dissipation characteristics? Is there any other reason?
