Charles Bradshaw
First of all, I am not talking about caving. Most everyone knows what natural caves are. What I call urban caves are nothing more than the interiors of manmade structures, whether above or below ground level.
The dangers of fumbling around in total darkness in urban caves is essentially the same as in natural caves.
First Premise: It is not an urban cave until the power goes out, there is no emergency power failure lighting, and no outside light to help out.
Second Premise: This is about getting out of the situation (evacuating), and not exploring (as in caving).
Third Premise: A flashlight or headlamp is required in order to prevent injury or death. (This is why I call this an urban cave.)
The goal: Getting from the point of flashlight required to the point of not required.
Now for the complicating factors........
Cause of outage is unknown, unless obvious like an earthquake, but, not something that you see coming, like a hurricane (which would nullify this scenario).
Duration of outage is unknown.
You only have one light on you when this happens, with no spare battery(ies), and if incan, no spare bulb.
The Batt(s) in your light are partly used.
If you EDC more than one light at the time, they are NOT on you, and may or may not be in the same physical space as you are.
Date, time, and place are unknown, as is the length of time required to acheive the goal.
The light you have on you, is the one you happen to have on you at the time. We all know that our EDC light(s) can and do change. This scenario could be 10+ years into the future, so you cannot state what light you will have on you at the time.
Final rules:
1. You are in a manmade stucture at the time.
2. You are not at home. So your stash of lights is not available to you.
The question: Is your always on you, just in case light going to be adequate under the conditions stated above??
Keep this in mind: The shorter the runtime, the less likely the light will be adequate to acheive the goal. /ubbthreads/images/graemlins/grin.gif
Final rules:
