dpolseno41
- Joined
- Apr 10, 2014
- Messages
- 3
If you had the chance to design an end all, be all survival light that wasn't large in size, what features would you try to stuff in it?
I would design it so that it would meet as many survival needs as possible in a small container. I'm thinking of the altoids tin pocket survival kits.If you had the chance to design a survival light that wasn't large in size, what .. would you try to stuff in it?
Life+Gear's GLOW Flashlight is the ultimate water resistant flashlight for everyday use.
Read maps, signal your friends, or light up your path with this multi-function flashlight that also glows and flashes. Not only will you feel comforted by the reliability of this bright LED light, but you can also use the handle for storing keys, bandages, or money. Just twist to open.
1. Of course, it would be made from titanium, with top notch anodising.
Yea, you're probably right about the cost point. However, I was under the impression that we were fantasizing rather than engaging in realistic cost evaluations.Why "of course" titanium? Makes it MUCH more expensive. Could buy several hard-anodized aluminum lights for the price of one titanium light...and having two is always better than one. ANY light can fail, regardless of how tough it is...and the aluminum body is typically not the weak point anyway. Much more likely to have switches, or electronics, and even O-rings fail.
If your answer is "I've already got enough lights" then I suspect this thread isn't for you. In fact, I suspect that this forum isn't for you. :nana:I already have more than enough lights...don't need to design a purpose-built Armageddon light. No light will last forever, even if it is very efficient. In my opinion, it is better to invest in a solar charger, and some extra batteries, rather than obsessing about modes and runtimes.
I agree that a SHTF light should be JUST A LIGHT.Personally I think a SHTF light should just be a light, but a good one.
Oh... and Naz,
If this was meant to be humorous, it didn't over very well with me.
Some SURVIVAL KNIVES have hollow handles with fishing string, and hooks.
I didn't mind...in fact I've said a similar thing myself...it seems to be a standard CPF running joke.
If you want silly, you need to check out this review of a hollow-handle survival knife. Takes a while to build up (don't know how he kept a straight face) but it is hilarious.
Very easy,a real silly low about 1/2 a lumen.....about 50 to 60 lumens as workable on long hours and a massive 500 or more for those bigger jobs,must run on the worlds easiest to find batteries so AA/AAA
