Ok, so I purchased a Jansjo desk lamp from Ikea with the intention of using it as a light for a 5 gallon desktop aquarium.
Well I am trying to grow plants, and the stock LED was far too warm for that purpose. So I ordered a Cree XM-L2 in 6500k to replace it. Well what I didn't realize was that the existing chip/LED in the Ikea lamp has built in driver/voltage control functionality and that I would need a separate driver to run my new Cree LED.
So, I went to FastTech and ordered a 3v-4.2v 1-Mode LED Driver Circuit Board and a different 3v-4.2v single mode driver. The idea was that these would reduce the stock input voltage down to the ~3.2v-3.6v needed to drive this LED. Well it doesn't work that way. When hooked to either driver, the LED just blinks.
So I busted out the old Multimeter and checked things out.
The specs for the power supply on the Ikea lamp is below:
When I connect the multimeter to the power supply I get a consistent reading between 4.2v-4.6v. The LED drivers should be putting out around 3v, and for sure less than 4v. Instead, I get the following results when power is applied:
and
I am baffled as to why the voltage would go up. Can anyone offer any suggestions?
Thanks
[h=1][/h]
and
Thanks
[h=1][/h]
