Re: The Light I\'d Really Like to See in 2004 is...
I would like to see a light that uses 4 123 batteries in a 2x2 arrangement like some of the 4AA lights use driving a 5W luxeon. I would like to see it adjustable in brightness between a low setting that would still preserve night vision to a high setting approximately as bright as a Space Needle II. I would like it to have a recessed clickie switch for signalling or turning the light on or off, but would still allow you to stand it on end in candle mode. It would not need to be totally waterproof, but I would like to be able to use it on rainy days without water getting inside.
I would prefer being able to adjust the brightness by turning the head. That way, if you like a certain brightness setting, it would turn on/off at that preferred brightness setting.
