EvilLithiumMan
As an alternative/adjunct/compliment to bmccue1964's post, here is a Li-Ion mod I've done to a 6V lantern. These days I have a preference for Li-Ion when it comes to rechargeable cells. Superior charge retention and low temperature perfomance compared to Nicad/Nimh. And even though it's been years since I've used SLA, I still recall how quickly they perish when discharged too deeply.
The host lantern is a Ray-O-Vac model. $9.99 and $8.99 at Home Depot and Walmart in my area. I was intrigued by it's 4 D-cell adapter; that was why I selected this model.
(In another thread, it was correctly noted that this adapter is available from www.digikey.com - for only $2.70 apiece. I don't know if Digikey has a minimum order requirement. Their part number for this item is BA4D-S-ND).
The Li-Ion pack is a Canon BP-945. 7.2v at 5500mah; replacement packs can be found on eBay for approx. $35. Often times less if you are patient. I got both of mine for $22 each.
The 7.2v pack is too hot (8.4v) out of the charger for most 6v bulbs. I've selected a KPR-118 bulb from Radio Shack, 7.2v @ 600ma. I've had up to 9 1/2 hours of run time per charge. Yes, then beam is full of artifacts. But this is meant to be a 'You better be working even after sitting in the trunk of the car for a full year unattended' light as opposed to a 'Let me impress the neighbors by taking down a 747 Jumbo Jet with my 50 million cp' light.
Biggest downside is charging the pack. There only seems to be quick chargers for 7.2v 1850mah packs. Expect to spend anywhere from 8 to 9 hours to get one of these puppies topped off.
