Howdy ozarkguns, and welcome to CPF!
This definitely sounds like a QC issue, and I'm glad you were able to correct it so easily. The SC600 is a wonderful light, which I'm sure you'll find out for yourself as you begin using it.
Oh, by the way, it's always a good idea to do a quick inspection of a new light, which often includes a quick cleaning of the threads (as well as relubing of threads and O-rings), to get rid of any burrs left over from the factory, as well as a quick cleaning of all electrical contact points, which would include the positive contact point in the head of the light, the negative contact point (the spring in the tail cap), as well as the bare metal end of the battery tube and where it makes contact in the battery cap.
When cleaning the positive contact point in the head, I generally use a Q-tip on which I've sprayed contact cleaner (or Isopropyl Alcohol in a pinch). Then hold the head up, with the opening facing down, and insert the swab and clean gently. This way no cleaner runs down into the head or the electronics.
Have fun!
