A laptop supply may not be designed with anything like a precise current limit. Also, it may very well not be designed to run reliably at current limit.
I would strongly recommend some sort of device to limit the current to a safe level (6A total). Resistors are the simplest, but in your case may not be able to give you full power. If your LEDs are 8V at full power, the math says you need zero resistance and you have no control over the current. A slight change in the system (like Vf drops as the LEDs warm up) will cause an overcurrent condition. On the other hand, as idleprocess shows, you may have plenty of overhead for proper control. You'd have to test the LEDs at power to know for sure.
A buck-boost driver could drive strings of 2 LEDs, or a boost driver could drive strings of 3 or more, or a buck driver could drive them all in parallel.
If you want to investigate the LEDs, just get a couple of 1 ohm, 2 watt resistors, hook them up, and see what happens. 1W is probably enough, but most resistors get REALLY hot at rated power.
