Hello folks,
Ordered a EagleTac MX25L3C kit flashlight with Nichia 219 B11 LEDs. Researched the battery requirements but information I'm certain about is a bit incomplete so am hoping to receive some advice from you experts thankyou. The EagleTac spec web page for this model shows:
Compatible battery (diameter/length)
18650: (18-18.8mm/67-68.5mm)
Have not bought any of these 18650 batteries before and quickly noticed dimensional parameters vary, button-top versus flat, and protected versus unprotected. So read up on such. Also looked at the useful 2012 Battery test/review summary thread herein and others. Having looked at the dimension specifications of various 18650 lithium ion 3.7v batteries, have found not many high drain batteries of greater than 5 ampere maximum current draw actually are within that size range. The one battery often used is the very expensive EagleTac 18650 3400mAh protected Li-ion Battery which is priced high at $19 each. Am considering buying 3 of those plus 3 spares of lower cost for usual charging swap in out and a charger.
Without spending even more time hunting down all the possible compatible battery models am hoping some others have already gone down this road and can pass on what other 18650 batteries models are known to fit and work with the MX25L3C?
(Note posted herein years ago before buying Fenix products but under a forgotten user ID. Also have worked a few decades as a tech mostly in electronic engineering groups here in Silicon Valley. )
