So, I got a bit of a hankering for a Zebralight headlamp because I keep reading about how great they are, and something like the H502 would cover a couple of things I don't currently have: namely a decent mule and a lightweight head/shirt lamp. But while reading up on exactly which Zebralight would be best for me, I noticed a lot of complaints about the fact that the H502 series doesn't support 14500 Lithium Ion batteries This even seems to have caused some people to opt for the H52Fw instead.
Here's the specs for the H502d L2, which is the one I'm pretty much settled on:
http://www.zebralight.com/H502d-L2-High-CRI-Daylight-AA-Flood-Headlamp_p_142.html
I noticed an odd discrepancy here. It explicitly states that 14500 is not supported, like everyone says. But it also says the maximum voltage is 4.2V. This makes it sound like one of these two statements may be an error.
So I contacted Zebralight, who just replied. Apparently it DOES support 14500. Here's what they said, exactly:
I've replied back pointing out that the Eagletac 14500s that I use are only 1mm longer than an AA Eneloop, so my guess is that it would fit OK. I don't expect them to reply guaranteeing that it will though, so I thought I would check to see if anyone here has one and has tried it, or perhaps was previously too scared to try it because of the "not supported" warning in the specs, which most would interpret to mean "it will burn out the emitter", not "it works but we don't expect it to fit".
"The driver can support the 4.2V voltage, but most of the 14500s are too long to be fit inside. If, however, you do find an 14500 that can be used with the H502d, you'll get all the levels with the H1 being slightly brighter."
