Hi all,
been using my Klarus st 11 for almost a year now. About 2 weeks ago, it has been working intermittently for no apparent reason.
Has seen regular use, NO abuse. Tested fresh 18650, which worked in another light, so that wasn't the problem.
It has seen zero drops, bangs, water even. It sits on a nightstand and in my pocket.
It's the tail switch that is giving me a problem- Clicking on and off about 20-30 times and trying to fenagal <sp? yiddish?> the button around to see if it helps, it doesn't.
It's not the side switch that turns it temporarily off. Then out of nowhere, it will come on in the last mode I left it. Then it continues to work continously, and switch on and off fine, until I leave it off for about an hour, then the same problem occurs.
HELP plz!
HELP plz!
