Sorry about that previous post. This is the first time in reading /posting from the clf android app. ...
I also have condensation on my alpha. But it seems a bit more excessive than the pictures I've been seeing searching the forums since last night when it happened.
My alpha is about a month old. I've unscrewed both tail cap and head to inspect threads, o ring, and lube upon arrival. This was my first high end flashlight. Everything seemed in good order. I was very pleased with the craftsmanship.
I was showing off to my 5yr old son and dunked the light in the tub (warm water) then later (about 10 minutes) in cold water glass to see if the cold water would help cool the light since i know it gets a little warm while on high (about 2 minutes). Then i took it out of the water.
This is when I noticed the condensation. I read that its common but haven't seen pictures that are similar to how mine looks. Please forgive me if I'm panicking over a non issue.
My question is this amount of water /condensation normal and will the usual desiccant packs inside the sealed tube remedy this much condensation? Thanks in advance for any info. I hope I'm posting in the proper area. Pictures below.
Paul
