CelticCross74
On the 3 lower modes I get flicker. On the lowest mode it is the worst. Ill mode switch over to the lowest mode where the light will come on for 3 seconds then flicker for another 3 seconds then go out completely. Oddly I can still mode advance from the flickered out lowest setting into the next one higher but there is still flickering. On the 2 modes above the lowest the light will stay on but will flicker still. The higher I go in modes the less flickering there is. High and turbo do not flicker at all. Ive heard this may have something to do with the ring inside the tailcap being loose so I tried tightening that. It did help a little now the lowest mode will make it 8 seconds before it flickers out. Ive tightened this ring as far as it can go. Any ideas?
