So it touch sensitive than ? That is pretty sweet...
I wouldn't call it touch sensitive, in the sense that a mere touch will cause it to change modes. It's basically like a pushbutton that wraps all the way around the body of the light. Pressing anywhere on the circumference has the same effect, just like pushing the side-mounted button on similar lights.
If you're familiar with weapon light tape switches, it's much the same. The "switch" has a rubber cover that goes all the way around the light and requires a little bit of pressure to make the mode changes.
It has a tail switch to turn off and on, but does the tail switch function in another way? The video claimed this light could be programmed to single mode. What configurations are possible specifically? The 360 side switch changes modes, programs?
The tail switch handles on/off and the 360 degree switch at the head handles mode changes. The programming is (I think) just like the MMR-X where the user can select from one of 5 different mode groups . . .
- Single Mode: Max
- Two Modes: Max-Low (default)
- Two Modes: Max-Strobe
- Four Modes: Low-High-Max-Strobe
- Eight Modes: Moonlight-Low-High-Max-SOS-Strobe-Beacon (high)-Beacon (low)
The one at SHOT was set up in the default mode so I don't know for sure that the other mode groups are the same.
