AmicusCuriae
- Joined
- Oct 9, 2010
- Messages
- 27
Hello all,
For Christmas this year My wife got me a Malkoff MDC Tac which will hopefully be replacing my old HDS EDC 170 Tac as my duty light. I've been testing it out today and have gotten some strange results and am trying to determine if there is some issue with the light. The Malkoff doesn't come with a manual and I am not 100% sure how its UI is supposed to work based on the website so I was hoping for a little help from those of you familiar with the Malkoff EDC lights. When I turn on the light with a click, it goes on to high, but if I double click from the on position, it doesn't change modes - it just stays in high. The only way I can change modes is by cycling through each mode with a momentary press. Is this normal? Also, how long does the light need to be off before it defaults back to high when it is turned back on? I have to leave mine off a good 10 second otherwise it will turn on to the next mode in the sequence.
Any help you all could give would be appreciated.
Thanks,
AC
Thanks,
AC
