giulio1993
- Joined
- Jan 2, 2013
- Messages
- 4
Hello,
I'm a complete newbie but I'm trying to understand how I could build my first torch reading project on this forum and on other websites.
My first project is to completely modify a petzl zoom headlamp (originally with an old halogen bulb) with a high power led. The light is intended to be used for caving and it should normally run at around 150/200 lm, with the ability to quickly burst at around 1000 lm if needed.
This is a similar project: http://www.whitbyseaanglers.co.uk/forum/index.php?topic=30347.0
I want to power it with a 3.7V battery pack (would a 7.4v be better?).
For the emitter I tought about the cree XM-L U3, do you think it's good for my project?
My next two questions regard the driver and heatsinking:
- The driver should have both temperature protection (since I expect it getting very hot at full power) and low voltage protection (some warnings or something that reduces brightness when batteries drop in voltage). Looking on fasttech I found different drivers whit these features but I couldn't find any with both of them, can you help me?
- The petzl zoom has a plastic body so I expect it to get very hot, especially at high lumens. Ok, 1000lm will be only used for seconds so it shouldn't be a huge problem, but what kind of heatsinker do I need to use to run the light at lets say 200lm?
Thank you!
Thank you!
