magnum70383
I have aw 18650 2600mah cells. I insert the batteries, twist it to a close, nothing; oled doesn't turn on. I have thrunite 3400mah cells that work... What's wrong?
Here's a quickie test to see if the battery tube is making a ground.
With no batteries in the light, screw the tube all the way onto the TM26 body. Now take a marker in place a line lengthwise between the body and the tube.
Insert the batteries and tighten the same way again. If the mark doesn't align, the batteries are keeping the light from making contact.
As was asked before, are the AW cells button topped or flat topped? You didn't answer.
Doh! O well... I have 8 thrunite cells... Lol. Although it looks like the thrunite cells are also flat top...???
Just go to eBay and purchase some 3mm rare earth magnets and some arctic silver adhesive.
A dab of arctic silver on the magnet and apply to the + terminal.
Problem solved.
Thedoc, you won't see an increase in resistance using the magnets provided you used the arctic silver adhesive.
I used to purchase Loctite rear window defogger kits, but the Arctic silver has better bond ability and extremely low resistance.
The plus side of the TM11,15,and26 lights is that you've got lots of open space unlike other lights where the contacts are buried inside.
