Vinz
Hi, folks!
It has been a long time since I have shown the last creation or modification. Mainly, because I'm working on something big, which will be released in a few months!
But following at least a small mod, which I did for a member of the CPF.
They are sinner custom hosts, modified by myself and equipped with some technical blinb-bling!
Cu-host:
Triple XM-L2, de-domed and "diamont treated" for a less greenish tint and slightly higher output. Direct soldered to the copper heat sink. Over 10 amps on high (depending on the cell). Of course, with overheat protection.
Ti-host:
De-domed XM-L2 U3, "diamond treated", for a nice cool white binning without tintshift into green, even at low currents. Equipped with a clear TIR, which was modified to fit the lover focus point of the de-domed LED. Plus a deep red stand by LED. With overheat protection, too. The result is a quite powerful thrower for it's size, with tactical qualities. There is a bright spot, surrounded by a corona twice the size and a very weak spill. Most of the light is into the spot.
Both have the same Interface:
There are four main groups, which can be activated by 7,8,9 and 10 fast clicks. A red stand-by blink mode on the Ti-host can be activated with 5 fast clicks and a voltage monitoring feature with 6 fast clicks.
The mode groups are:
EDC (Every Day Carry): Moon - Low - Medium - High
(starts always on "moon" if the light was off for more than 0,7 seconds and mutes the moon mode if you circle through the modes.)
Regular Mode Memory: Low - Medium - High
(saves the last used mode if the light was off for more than 0,7 seconds.)
Police / Law Enforcement: High - Medium - Low
(starts always on high if the light was off for more than 0,5 seconds)
Tactical: High - Hidden Strobe
(the strobe can be activated with a fast double click und uses a mode memory. So you can directly start with strobe, if needed. A short interrupt within 0.5 seconds brings you back to the high mode)
Cu-host:
Ti-host:
