So, about a month ago, I asked if there was any way nano oil could be causing a short, because my E05 SS had started coming on whenever the head was attached instead of only when it is fully screwed down like it's meant to. Everyone agreed that nano oil isn't conductive, but for whatever reason after I cleaned out the head and threads with some alcohol, the problem went away (now I think that might have been a coincidence). I reapplied nano oil and everything was still fine - I assumed something must have got in there to cause a short, even though I couldn't see whatever it was.
Fast forward to about a week ago and it starts doing something else. One minute the light is working normally. The next, as I try to cycle through the modes, it just goes dead. So I check the cell with a DMM and the voltage is fine. Try another, fresh cell: still dead. Try primaries: still dead.
So I assume the circuit has just blown somewhere and it needs to be sent back, but the next day I try it again and it works. For about 5 minutes. Then it's dead again.
I repeat this testing process over the course of several days. Each time, the light is fine for a few minutes and then dead. Wait 1-2 days and it works again. Yesterday I noticed that sometimes it doesn't respond to an Eneloop, but if I insert an Energizer Lithium (newish, showing 1.72v) that seems to wake it up. But then switch back to Eneloop and it stops working again. Yesterday, I managed to get it to start/stop a few times, until it eventually just died completely and the Lithium couldn't revive it. Sometimes it would run on the Eneloop for a few seconds, but usually not.
Today, I tried an Eneloop first (dead), then the Lithium (awake) and now it's running again (on the Eneloop) for a new record time (still working after about 30 minutes and I've tried switching it on/off several times), but I don't trust it at all. I mainly keep this light in my pocket as a backup, so I want to know it's reliable in case I find myself needing it.
I don't think it's a problem with the cell terminals not being the right size, because it was running on the same Eneloop cell for a couple of months without incident - it's just in the past week or so that it's started doing this. It never seems to just cut out when the light is engaged. It's only after you loosen the head and tighten it again, sometimes it doesn't come on.
Any ideas WTF might be going on here?
