Can it be done to most lights? Would you want to? I'm of the understanding that it increases flood. Please post your mule beamshots if you got them! Anyone ever see a mule before and after beamshot? I'm considering this mod for in house lights.
I amI'd be happy to grab some beamshots if anyone is interested.
I'll grab some beamshots tonight then and post them up I'll compare to a standard medium-floody flashlight for reference.
Quick set of snaps. I used three lights with different outputs so I adjusted the brightness to best show the beam differences.
The lights in order are:
Shiningbeam Blaze (a medium floody light)
Armytek Tiara (Wide angle headlamp)
XP-G drop-in /w Solarforce Convex lens
Thanks! What would you say the beam angle is? Roughly 100 degrees? Looks like it could be more useful than the 120 degree mule I have currently.
No problem at all. Yep the Solarforce creates a very even and useful flood beam. The only similar beam I have is from my Preon P0. For anyone dabbling in P60 hosts looking for a close range only light I would recommend swinging the ten bucks for the lens.
I'd say 90-100 degrees is a pretty reasonable guess. It is about as wide as the spill on many reflector lights. A mule will always be a little wider as the emitter will not be limited by the angle of the light that can escape the head. This is, to my understanding, because in a mule light the emitter is usually pushed forward towards the bezel more versus being recessed.
