BeastFlashlight
I heard MTG2 causes lots of heat but not sure what 'Lots' means. Someone made a good point to me that doubling the voltage cuts the current (heat) in half. Well then surely 1 MTG2 at 7.4 volts has to be cooler than 2 XML2s at 3.7 volts correct? And how about 1 XHP70 vs 2 XML2s? And how about 1 MTG2 vs 1 XHP70?
I have a light that has great heatsink and it is a 4 XML2 light and it can run for almost 20 minutes before getting too hot, what would be superior to produce the least heat, to convert it to 2 MTG2s, convert it to 2 XHP70s, or to leave it alone and just upgrade the XML2s to XML2 U3s? Also would the 2 MTG2 or 2 XHP70 setup produce as many lumens at 4 XML2 U3s? Thanks
