Mr. Nobody
Anyone have a suggestion on removing the bezel on the nitecore p12 without damaging the finish? i see they use RED loctite (which could be any strength). I was thinking about using a heat gun slowly raising the temp and using Rubber type grippers to break the loctite loose. how ever i am concerned it may damage the emitter? if all else fails and i end up marking the bezel has anyone tried polishing it? I know this isnt an easy task but it is not impossible.
