Capolini
Banned
This is pertaining to LED flashlights only! They are the only kind I have and the ones that I used for this experiment, if you will.
This may seem like mostly common sense, But I wanted to be sure. OK,,,,,I have numerous modded and high powered lights. They all generate a lot of heat. Rule of thumb is when they get too hot to hold dial them down. I actually turn them down before that. When my thumb which is near the neck/switch/control ring, begins to feel too much heat I dial it down a notch or Two!
Here is the situation. It is winter time and snow is on the ground.The light is starting to get hot. I got this brainiac Idea to put the head of the light in the snow for ~5 seconds. The light was cooled down immediately as one might expect! Hey,,,,,now I can do another 15 minutes or so of a run on turbo! This light puts out~ 6800 lumens. It is One of only Two that will still get hot when temps. are below 20F/6.6C.
I only did this once and I will point out that even when this light gets too hot, it is thermally regulated to protect it. My thinking is no harm no foul!
How about for a light that is NOT regulated like this? Or even this light if I did repeated runs of turbo after cooling in snow?!
Even though the outside of the flashlight is cooled,,,what about the driver and other internal components?
These are my thoughts:
I THINK THE "ACT ITSELF" [COOLING IN SNOW] IS HARMLESS TO THE LIGHT. HOWEVER, WOULDN'T REPEATED RUNS OF CONTINUALLY BUMPING BACK UP TO TURBO BE POTENTIALLY HARMFUL TO THE DRIVER AND OTHER INTERNAL COMPONENTS?
What are your thoughts Ladies and gentleman? Could I have possibly resolved the enemy called "Heat",,,,,,,,,,,,,,just for the winter?!
