Here it is. Cree's new "XLamp XP-E2 Torch" LED.
Specs per Cree;
Cree XLamp XP-E2 Torch specifications:
Standard Cree XLamp XP-E2 specifications:
Viewing angle change to 125°. Maybe different dome. Have to get a hold of one to find out.
I noticed they used the same photo for E2/E2 Torch. Does anyone know what the increase is actually coming from when compared against the standard XP-E2, besides the specifications change?
The change is something but appears to be a very high bin of the same design. It's a new LED listing now rated at 89% the lumen output of the XP-G2, where before it was rated at 55% the lumen output of the XP-G2. The total gap in surface area between E2 and G2 die is much larger than 11%! I'm starting to draw conclusions now...
Specs per Cree;
Size (mm x mm) | 3.45 x 3.45 |
Maximum drive current (A) | 1.5 |
Maximum power (W) | 3.5 |
Lumen range | 360 – 456 |
Typical forward voltage @ 1.05 A (V) | 3.5 |
Viewing angle (degrees) | 125 |
Binning | Torch |
Thermal resistance (°C/W) - White | 9 |
Reflow-solderable | Yes – JEDEC J-STD-020C-compatible |
RoHS and REACH-compliant | Yes |
Product options | White, Color |
Maximum drive current (A) - White | 1 |
Maximum power (W) - White | 3 |
Light output - White | Up to 283 lm @ 3 W, 85°C |
Typical forward voltage @ 0.35 A (V) 85°C - White | 2.9 |
Viewing angle (degrees) - White | 110 |
Binning - White | 85°C, ANSI |
UL-recognized component | Yes – Level 4 Enclosure Consideration |
