whc
Received this little throw monster for testing a month ago, and have been my daily go to flashlight ever since. It got impressive output easy charging by 12v car charger (or with included charge cap). It is a great all round flashlight, mostly for outdoor hunting, camping and so, but also just a good flashlight to have in the car or for general use.
Manufacturer Details:
Model: C26
Material: Head and body part is 6061-T6 aluminum alloy, bottom is 304
stainless steel.
Surface: HA III surfacing, dark grey.
Weight: 280g,including battery,packing not included.
Dimensions: 156MM long ,diameter of head is 45mm, diameter of boday is
31mm, diameter of bottom is 35.5mm.
Battery: Each has one 26650 3.7V rechargeable lithium battery.
LED: CREE latest XM-L2 LED,the maximum luminous flux is 1000LM,
Runtime: H: 150 minutes L : more than 300 minutes.(Different battery
causes some difference.)
It is IMO a greet looking flashlight, it fits comfortably in my hand, and the digital switch it easy and assuring to use.
The flashlight can easily be charged in the cars 12v power outlet or with the included charging-cap, that can take both micro USB and lightning connector, so no excuses to run out of charging solutions.
The built quality of this flashlight is excellent and fit and finish is also very good, felling like a it could take some beatings.
When it is time for charging the little red LED lights, then just plug in or swap out the battery.
Here it is next to some other flahslights for refrense.
A short video to see it in live action.
Now to some beamshots, first off some shrow shots, then some beamshots on white wall.
Off
Hi
Low
Off
Hi
Low
Now to some white wall beamshots, about 1m from wall all on same camera settings.
Hi
Hi -2.0
Low
Low -2.0
Some lux readings:
Heat after 20 standing on the face: 47,2 celsius
Overall it is a great and unique flashlight, that I can highly recommend. Any questions don't hesitate to ask and I will do my best to answer them.
Model: C26
stainless steel.
Off
Hi
Low
Off
Hi
Low
Hi
Hi -2.0
Low
Low -2.0
Some lux readings:
Throw: High: 377000 lux, Low: 79800 lux
Overall: High 433000 lux, Low 93200 lux
