Capolini
Banned
I have a budget light called the DQG Tiny Triple XP-G2 26650. I noticed the bezel was loose. Instead of tightening it I decided to check out the LED's. After doing that I put the optic back on and tightened the bezel. Something did not seem right! What happened is when I Put the optic in I did not align the Three stems in the holes they are assigned to! so when I tightened it I partially de-domed Two out of the Three LED'S!
Here are a few pics. w/ my C20Cvn.
I did not get mad,,,I was actually laughing at my lack of concentration and stupidity!:shakehead It's ok,,,,,,,,,,I have a great idea. I will do my best to finish the de-doming the Two LED's that got partially de-domed!
Amateurs have to improvise. So I got my magnifying glass[helpful tool] and my Steak Knife! I went to work very carefully and meticulously scraping away the silicone dome.I am about a minute or Two into this and I said to myself,,,,,,HOLD ON CAPOLINI!!! You need to take the battery out for safety and take the head off so it is easier to work on. So I did this and meticulously worked on getting the rest of the domes off for about 10 minutes. I must say, it did not look too bad! I can't wait to see what Two dedomed and One domed beam looks like!
Well, I put it back together and NOTHING! So I got the magnifying glass out and I notice that the RED Wire was burned!:sigh: No doubt that I hit the exposed part of the wire at the solder joint.
It was Only a $40 light but it was a light w/ decent output[~1300 lumens] that produced beautifully diffused light from its TIR optic lens.
My guess is that I fried the driver. I don't have the proper tool to get to the driver. The beard/mustache trimmer scissors[!!!] that I have that work to take apart the tail cap/switch, will not work for this. It may even be glued?
Would you guys agree or could it be just a resistor or some other electrical component shorted out?
It certainly would NOT be worth it to send it To Vihn or someone like him. I would believe that Two way shipping costs plus repair would at least equal and probably exceed $40!
It gives me an excuse to get another torch! I only have 4 EDC'S left now! I am keeping my EYE on that Nitecore EC11 plus a likely "VN" attached to it!
