Is this statement true!?
lordraiden
Ran into this statement while researching, of all things, battery chargers. Does anyone know if this is true? It seems a little too simple to be right. Well, to me at least.
A battery's capacity in mAh is 10x a flashlight's run time in minutes.
The Math:
The bulb in a P700 or P703 flashlight draws 600mA, and there are 60 minutes per hour, so a battery's capacity in mAH is (run time in minutes)/(60 minutes per hour)*(600mA draw rate), which can be reduced to (runtime in minutes) * 10. A fully charged P103 running at full capacity should keep a flashlight lit for 1300mAH/(600mA)*(60 min/hr) = 130 minutes. If the flashlight stays lit for only 90 min, then the battery's capacity is (90 min)/(60 min/hr)*(600mA) = 900mAH.
Bear in mind that the bulb doesn't draw EXACTLY 600mA , but I bet the actual number is within 30mA. So this method should give a measurement of battery capacity to within 5%, which I'd say is pretty darned good.
yellow
Baden.at
in case of 600 mA draw, that is - just by accident - true.
Try it with 1000 mA draw
or with 500
better use the full (the non "reduced") one ...
(= current draw * runtime / 60)
lordraiden
Ah, okay. Wasn't sure about that as I could quickly see this running into Peukert's law and being nullified, and based on what I'm reading it does to some degree.
openbolt1
I always tried to simplify the formula in my head by using this example:
Light draws 1 amp (lets say).
Battery capacity is 1000mAh (let's say).
Answer: you have roughly one hour of use from that combo.
It's worked for me but I'm a simply man...
Sent from my iPad using Candlepowerforums
fivemega
California
That is true for lower current draw but when current draw goes higher and higher, then some of battery energy wasted in form of heat.
Assuming all current draw of following examples are acceptable by battery manufacturer.
Example 1:
Light draws 2 amps (lets say).
Answer: you have roughly 1/3 an hour (20 minutes) of use from that combo.
Example 2:
Light draws 4 amps (lets say).
Answer: you have roughly 1/8 an hour (7.5 minutes) of use from that combo.
