Sold/Expired SOLD: Novatac USA triple
Flucero28
Hello all,
I put a bit of work into this one, its a really neat build. The reason I am looking to sell it is to free up some funds for something else. So here is a description:
- Silver novatac USA with extended button
- Lux-rc 333 triple led board with neutral (4000k) cree XPG emitters. Beautiful tint on these. This board also has a red micro led which serves as a status indicator, battery indicator and can even be a great low low mode.
- A custom heatsink was machined to house the lux rc board and optics out of aluminum.
- The reflector end of the light was bored and faced inside to provide a flat surface for the triple/heatsink. The heatsink was secured to the inside of the housing with arctic alumina adhesive for good thermal transfer.
- Mil-spec multi strand copper wire with heat resistant silicone insulation was used with the positive lead soldered directly to the positive spring for minimal resistance.
- Carclo clear narrow beam optic.
- The stock heatsink/ battery pcb was retained on the battery tube side giving a completely stock look inside while retaining the functionality of the momentary switch input.
This thing puts out a wall of beatufully tinted light and has great low mode options.
The bad - I accidentally ground down a small area of the interior threads where the battery tube screws into the head the width of a small drill bit. This does not affect functionality at all, I just wanted to disclose.
Here are some pics:
I would like $205 shipped USPS priority.
Thank you for looking at my thread and please ask any questions as I may have missed something.
Edit: This PDF:
(https://drive.google.com/file/d/0B-4vSwN8pFVnSlE3ZDd2SGR1cjA/view)
explains the user interface on page 3. Thank you again Isaacl. Just to clarify this light is using the lux-rc board UI, not the novatac driver. It has been removed.
Frank
moshow9
El Paso
Re: WTS: Novatac USA triple
Probably not needed but I'll take backup!
Flucero28
Responded to your pm drillbitz SPF. Moshow has backup in the event drillbitz backs out.
Also added a link to a pdf that explains user interface on page 3.
Flucero28
Deal fell through with drillbitz11, its yours if you are still interested moshow9
Nicrod
So Cal
NovaTac modded triples are sweet lights. I have a couple myself.
This is the first I've seen with a secondary Red light source, besides the Ra twisty. Such an awesome idea.
recDNA
Really nice grab. What a great idea.
moshow9
El Paso
Light arrived today Frank, really digging it. Thanks again mate!! :thumbsup:
