realista
- Joined
- Aug 16, 2014
- Messages
- 208
hello i bought this 12v switch http://www.banggood.com/12V-30A-LED-Light-Car-Boat-Auto-Rocker-SPST-Toggle-Switch-12mm-p-956774.html
i connected this in this way and the led is ON, and the bottom barrel is WITH current. so basically the switch is at ON STATE. and no cable heats up.
t
hen i connect in this way, it should be OFF state. led is off, and bottom barrel is WITHOUT current. but unfortunately something heats up the cables... BOTH cables. why?
if led is nopowered,,, what current is passing throught the switch?
this is the precise scheme of the labeled switch. maybe i am doing some error?
i don't understand if this switch is SUPPOSED .... that when OFF > led is ON or............when OFF> led is OFF .
please someone explain me. because i tryed another kind of connection with + pole of battery in bottom barrel, and - battery pole in higher barrel. THIS WORKS OK(in the central barrel current do pass when led is OFF....) but in this way the led is ALWAYS ON WHEN IN OFF STATE. it could be supposed to be used in a "car".... but i need to use with a battery so i can't always power that led.... would drain all battery in weeks.......
t
