Barracuda. Search lights.
ArmyTek
Berlin, Germany
All Armytek Barracuda discussions in one place.
You are welcome.
Armytek Barracuda
  • Excellent throw for more than 700 meters
  • Maximal light output 1390 LED lumen
  • CONSTANT brightness in all modes
  • 50 meters waterproof
  • Record runtimes in all modes
  • Powered by two 18650 Li-Ion or four CR123A batteries
Armytek Barracuda v.2
Impressively bright light for 700 meters
Extreme brightness 1450 lumens with new XP-L LED and unprecedented beam distance up to 700 meters for efficient illumination of large areas.
Unsurpassed reliability
Ultra-strong materials and thoroughly thought-out construction guarantees total protection from faulty operation, which can be caused by harsh impacts or vibrations.
The flashlight withstands a fall from the 10th floor and even a direct shot.
Light-weight but durable construction
Due to extremely lightweight construction, the flashlight has minimal weight saving its excellent light characteristics and fail-proof reliability.
It permits to use the flashlight during long foot-mobile searching and forced marches.
Simple operation and continuous runtimes
The flashlight has easy operation and 4 brightness modes. Advanced electronic driver enables to get record runtimes with two 18650 Li-Ion batteries –
almost 2 hours at maximal mode and 17 hours at middle mode.
Constant light brightness
Full stabilization - constant brightness even when the batteries are nearly empty and at -25 C temperature.
You can be sure that even during continuous use light brightness will not decrease with time.
Armytek Search Lights
kosPap
Naoussa Greece
Differences in Baraccuda v2 specs?
in the Armytek website i see a differecne between the regular and the warm model.
The latter is shown to NOt have Built-in low battery indication
there is also another difference between the new predator's specs. the warm is marked as not to be able to tailstand.
how could this be?
furthermore, the Predator Red is speced NOt to ahve trapezoidal threads and that is unique for the prepdator models?
Why these? Site update glitses?
ArmyTek
Berlin, Germany
Re: Differences in Baraccuda v2 specs?
how could this be?
Yes, you can notice some inaccuracies on our official website. Sometimes it happens because of bugs when an identical characteristic can be applied for all products. If you notice any mistake, we will be grateful if you inform us. Thank you for your attention. We will correct it as soon as possible.
tobrien
Georgia Highway 441
that's a great, honest response. I like buying Armytek stuff!
scs
Armytek,
With regard to the Barracuda V1, what is the reasoning for spacing the high mode (~800+ lumens) and the medium mode (~150+ lumens) so far apart?
An additional 400 lumen mode in between would be nice.
Will the Barracuda V2, Dobermann, Viking and Predator V3 have such wide level spacing as well?
Thanks.
ArmyTek
Berlin, Germany
Armytek,
Thanks.
Hi!
Max mode in Barracuda has 1380 lumens, others have 820, 170 and 30. So it has 2 high modes and a medium mode (170). We always try to take into account the preferences of customers. :)
scs
Oh come on! He didn't even turn it on!
ArmyTek
Berlin, Germany
Any ETA on Barracuda v2s coming back in stock?
When all information preparations and exact measurements will be done. :) We will post all information for you, friends, here and on other social networks.
There is one more options for the products which are out-of-stock: now it is possible to request to be notified when the product is back in stock. Please choose the product which is out-of-stock and check the box "Notify me when this product is back in stock".
scs
Manual for v2 is up.
The jump from 1200 to 440 lumen. Why?
Is this based on field tests showing that there is no utility to having a mode in between?
Maybe it's just me, but it seems like 1200 doesn't run long enough, and 440 might not be bright enough.
At least the older model has a 800 lumen mode, which is not that much dimmer than the max mode, but with appreciably longer runtime.
ArmyTek
Berlin, Germany
Exact measurements will be done for the second time again and we will correct it on the website. :)
Toopy
Failed Armytek Barracuda v2 XP-L?
Hi,
Would have posted this in the service thread but its closed.
Recently bought a Armytek Barracuda v2 XP-L V2 the torch has worked fine for the last week, however this weekend it seems the torch has failed.
Simple will not power on/no light, have tried different sets of know working batts and tried the set that was in the torch in my V1.
Both the head and the tail cap are firmly closed and have tried all combinations of head loose, head opened and closed 3 times etc. but to no avail.
Was wondering if its possible that the mcu has locked up and if there is a method to reset it? I have contacted Armytek and am awaiting a reply.
ArmyTek
Berlin, Germany
Re: Failed Armytek Barracuda v2 XP-L?
Hi,
Good day! Thank you for your post here. :)
Yes, our service specialist has sent you a letter back. Check your email please.
It will be better if you`ll make a short video. It will help us to understand what is the problem and suggest you a solution.
Best Regards,
Armytek
SemiMan
Banned
Hi,
Should he make that video in the dark?
