It goes from min to max using the rotary dial, but doesn't turn off. Tried using fresh battery, same result. Is there something else I can try before sending it in? Its been used for good 3 to 4 years by a buddy. Thanks.
Although that's a good question, didn't the first production run of these /not/ have the 'off' detent? :thinking:When you rotate the switch all the way down past the dimmest position, does it "click"?
the pictures Minimus Vision above also "clicks" with a detent when switched off.eta: sorry Kestrel, overlooked your post when I responded - good call out about the first generation being different, perhaps.
I don't know if they have different versions of the Minimus (mine is like the picture below), but mine has a detent that you can feel "click" when it is turned off or on. Perhaps yours is different, though. I'd suggest calling Surefire and trouble shooting with them on the phone.
Its a weird Dome/TIR - but the beam is beautiful a nice wide flood of neutral light (pic above is one of mine, i dont use that X100 much anymore though)Nice photo, cland. Interesting lens on the Minimus.
It is very likely covered by their warranty. I have a first gen too. It has had a rough life. It too doesn't have the click stop. In fact, I didn't know the new ones did. lol Anyways, I never had a problem like this.
Just pondering, could some dirt or metal shavings gotten inside the light or switch?? Sounds like it has some crud built up on the switch contacts. Of course I have no idea what kind of switch it even has. Just a wild guess.
http://www.surefire.com/warranty
Its all good mate - you even linked from my photobucket.Hey Echo63, I used that picture because I found it on Google images - I wasn't trying to claim your work, of course! If you would like me to remove it, please let me know and I'll happily do so.
