Hi Everyone,
New boy on the forum, so I'll get my dumb questions out of the way in this post
I've just bought a TN12, having used a LED Lenser P7.2 and I'd like narrow the beam's spill (for light painting when out photographing stuff).
Obviously it doesn't zoom, so I'd like buy or make something that I can simply attach to the front to give me a narrow beam when needed.
The only thing I've found so far is the Nitecore NDF25 (which is a slightly tapered clear diffuser) h**p://www.nitecore.co.uk/Shop/Products/Accessories/12364-Nitecore-NDF25-Clear-Diffuser.html
My idea would be to drill a small hole (1/8" or 1/4" at the bottom, spray paint the inside silver and the outside black.
Do you think this idea would work or can you suggest any better bought or home made solutions?
Basically, I need a cone shaped attachment which is reflective on the inside and can be attached to a 25.4mm /1" diameter torch/flashlight.
I've tried the cutting a hole in a black card trick, and using silver card in a cone shape, but I'm wanting a more robust solution.
Thank you for any advice.
Mark
Mark
