Mr. Nobody
Is there a metal reflector out there for the 2xAA maglite ?
Aurora made incan kit for MiniM*g including aluminum reflector, glass lens and high temp bi-pin socket to use TL-3 bulb using pair of 14500 or Strion bulb with single 14670 in cut down body.Is there a metal reflector out there for the 2xAA maglite ?
That is Rad! I like that setupAurora made incan kit for MiniM*g including aluminum reflector, glass lens and high temp bi-pin socket to use TL-3 bulb using pair of 14500 or Strion bulb with single 14670 in cut down body.
This was back in 2004 and you may find one in BST of custom light.
You can bore the head to take a mcR reflector like fivemega did to the 14650 mini mags he is selling
Find my recent minimag thread. I already modded a MM and I want a metal reflector because it is just cool but maybe ill pass on one after what I did to a plastic reflector.I bought some Carclo triple optics that actually fit in the minimag head, but you'll have to do something for the star and room for a driver.
I have a half-finished minimag mod with a triple nichia 219 and triple carclo. It was going to be resistor DD, 14500 + 1 spacer.
Mr N, how hot were you planning on running?
