kj75
Another nice addition to the Sunwayman family:
http://www.sunwayman.com/html/products/201503/171.html
Interesting design, first time I have seen anything like it. But for the sidelight I would like to see a 2 lumen and 0.5 lumen mode, instead of strobe and SOS.
Are there similar designs from other manufacturers?
Not same concept, but similar in lateral flood LED (this imalent is more tactical and biggest). Imalent EU06 2015 version: Principal front LED XM-L2 white, two side flood LEDs (one white and one Red).....
Question guys, how is this light? is it a good thrower?
That depends a lot on what your definition is of a "good" thrower. But I would have to say no...it has a relatively small reflector, and a relatively large LED (XM-L2 has four times the surface area of XP-G2). It is best at 100 yards or less, even though the ANSI range is higher. The lack of a holster is also a problem for me, especially since the odd shape means that very few aftermarket holsters will work well. Last, and probably most important, the lack of memory when switching LEDs (and starting on high when switching) is a deal-breaker for me. I did try it out, but I was not a fan. The C20C is still the best of the bunch, in my opinion, despite the lower output. It is more compact, still plenty bright, and less annoying to use.
This light sucks big time. I have Vinh's modded version. It's not his fault the light sucks. It just does. Starting on low first and a lower low would make it a lot better. No dumb memory needed.
I have one and love it.I can't think of a better light to carry when on the road.With the magnetic base and side light it's great for changing a tire at night or working under the hood.Every light has it's strengths and this one is a great "Night Traveler".
