Just started "building" my first flashlights, SF C2's. I got two drop ins........(one high end)..... and one not so much. The high-end one dropped right in and fit nicely without the spring. Worked great!
The other one was loose without the spring.....(up and down).... and wouldn't seat on the rim on the body with the full spring, so I cut the spring to where the head would fit flush. It didn't work. I then wrapped the base with copper tape......(that came with the unit)....... and it works fine, without the spring. Not very Hi tech..... .... the only thing holding it from going up/down, is the "force" fit from the tape.
What is the spring for?
These lights have been around for a long time.......(so do not want to reinvent the wheel)..., but, it just seems to me, that the reflector rim should not be tight against the glass.....(no gasket or O ring).???
Thanks...Jack
Thanks...Jack
