Sold or relisted
Sold:
3) Novatac USA triple [Sold to kmart356] $195 $205
Modified by Flucero28 over on CPF. Tint is a nice neutral and is bright for it's size. Here is his description with original pictures (and mine below).
http://www.candlepowerforums.com/vb/showthread.php?397200-SOLD-Novatac-USA-triple
User Interface on page 3: https://drive.google.com/file/d/0B-4vSwN8pFVnSlE3ZDd2SGR1cjA/view
4) McGizmo Aleph 2 Natural w/4 level DatiLED [Traded]
I purchased the host on CPFMP and the light engine privately. The emitter is a 4500K XP-G2, runs at 1.5 Amps, and has a moonlight, low, medium, and high mode with memory. This light engine was built by DatiLED and will fit other DatiLED engines. Tail has a McClicky Switch installed.
5) SL2c Quad (vinhnguyen54) [Sold on another forum] $230
I picked up another SL2c along with this quad and decided I prefer the warmer tint of the other one. This has been tested a few times for comparison.
Note: Tint in real life not as yellow as in photos - this was due to the autobalance on my phone's camera.
Features:
6) VoB MT-G2 Copper P60 Module [Sold to Bellirr6] $65 - ships first class mail. $70 $80 $90
I picked up this module from Matt (vestureofblood on CandlePowerForums) as one of the first three in Batch #1.
A very nice looking P60 copper module with a lot of mass! It houses an MT-G2 5000K emitter. UI is low, medium, and high with memory. Powered by 2 IMR batteries.
Sold:
- Silver novatac USA with extended button
- Lux-rc 333 triple led board with neutral (4000k) cree XPG emitters. Beautiful tint on these. This board also has a red micro led which serves as a status indicator, battery indicator and can even be a great low low mode.
- A custom heatsink was machined to house the lux rc board and optics out of aluminum.
- The reflector end of the light was bored and faced inside to provide a flat surface for the triple/heatsink. The heatsink was secured to the inside of the housing with arctic alumina adhesive for good thermal transfer.
- Mil-spec multi strand copper wire with heat resistant silicone insulation was used with the positive lead soldered directly to the positive spring for minimal resistance.
- Carclo clear narrow beam optic.
- The stock heatsink/ battery pcb was retained on the battery tube side giving a completely stock look inside while retaining the functionality of the momentary switch input.
This thing puts out a wall of beatufully tinted light and has great low mode options.
The bad - I accidentally ground down a small area of the interior threads where the battery tube screws into the head the width of a small drill bit. This does not affect functionality at all, I just wanted to disclose.
Features:
SL2c
DriverVN (firmware by Dr Jones)
Quad XP-G2 4500K
Extra .3oz copper heatsink
"V54" hand engraved
Programming and driver information: http://www.candlepowerforums.com/vb/showthread.php?396548-DriverVN-A-User-Programmable-Circuit!DriverVN (firmware by Dr Jones)
Quad XP-G2 4500K
"V54" hand engraved
